Tria mesh and free edges
Hi guys,
I have a model composed by about 27 parts. This model is a STEP file. After importing the geometry into Hypermesh, I linked the parts in contact between boolean operations. Now the topology of the model is correct and I have created a 2D mesh of all parts. When I want to create a 3D mesh of all parts by tetramesh command, the status bar shows ' Tria mesh and free edges'. After I used Tools > Edges panel for check, there is ' no edges were found.Selected elements may enclose volume'. However, when I executed the Boolean operation and used the tetramesh command directly, I successfully created a 3D mesh of all parts. Who can tell me the reason? Thanks!
Thanks!!!
I have solved the problem. But there is a new problem. Could you help me?
'RBE2 174990 26374 0 3827 3828 3829 3830 3831'
*** See next message about line 26437 from file:
C:/Users/Zaily/Desktop/Altair_practise/HM/5_1_1.fem
*** ERROR # 1000 *** in the input data:
Incorrect data in field # 4.
As a newbie, I don't know how to solve the error according to the error message. Could you give some suggession?
Hi Shi Feng
Can you please share the model file
