undohistorystate
Beta
Beta New Altair Community Member
edited October 2020 in Community Q&A
Hi ,
I am trying to run a code like this
 *startnotehistorystate {} *replacenodes 7000139 7000103 1 0 *replacenodes 7000140 7000104 1 0 *replacenodes 7000141 7000105 1 0 *replacenodes 7000142 7000106 1 0 *replacenodes 7000143 7000107 1 0 *replacenodes 7000144 7000108 1 0 *endnotehistorystate {}
I use command *undohistorystate to undo the process. However, there is only one node was undo. I would like to undo all six nodes has been replaced. Am I missing something.
Welcome!
Answers
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    edited December 2017
    Maybe you have to call '*undohistorystate' several times?
  • Beta
    I tried, undohistorystate only affected once. nothing happened in the next use.
  • tinh
    tinh Altair Community Member
    Don't you provide a name for hist state?
  • Beta
    I tried to provide name also, but thing happened the same.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Toan,
    For *undohistorystate  please give the count also, and based on this count it undoes one or more history states.
    That is if  three times you have used *replacenodes, then  *undohistorystate 3 which will undo the  3 history states at once. Please try with this.
  • Beta
    hi,
    Thank you for the reply!
    I also tried to give the count also. Got the same issue!
  • Beta
    For your information
    I also tried to distribute each  *replacenode command into separated notehistorystate  with different names and use *undohistorystate with count 6.  It did not work
  • QuyNguyenDai
    Version Hypermesh?
  • Beta
    I use 14.2 version
  • tinh
    :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />  It has been disabled with tcl scripts. Please check release notes of version 2017
    I don't know how to enable it, maybe v2017 will do that
  • Beta
    I see, Thank you for your information  :))
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Toan,
    Undo/redo is not yet supported for Tcl even in HM 2017. Commands are available for future use, but they don't work.
    Regards,
    Oguchi
Welcome!
Welcome!
