trim solid
Hello, i want around the holes a non design space. so i want to make a cylinder and trim the solid.
but it don´t work.
how do i have to set the cylinders do i need an extra component?
or is there any other option to model he non design space?
thanks and best regards
You can try several different method:
Your geometry is very simple. It should work no problem.
