trim solid
Altair Forum User
Hello, i want around the holes a non design space. so i want to make a cylinder and trim the solid.
but it don´t work.
how do i have to set the cylinders do i need an extra component?
or is there any other option to model he non design space?
thanks and best regards
You can try several different method:
- Trim solid by line + direction
- Trim solid by cylindrical surface
Your geometry is very simple. It should work no problem.
0 -
thank you i will try.
do have tomodel the cylinder in the first component or do i have to crate a new one?
