Moving elements between mark IDs
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hi,
Is it possible to move elements present one mark ID to another without deleting the elements already present in the former mark ID ? I have elements in two diff mark IDs and I need to make use of both sets of elements by referring only one mark ID.
Welcome!
Answers
  • tinh
    tinh Altair Community Member
    edited November 2015
    Hi,
    I do not clearly understand your mind... :rolleyes:/emoticons/default_rolleyes.gif' title=':rolleyes:'>
    If you have some elems in mark 1, and you want to move it to mark 2, you can do:
    eval *createmark elems 2 [hm_getmark elems 1]
    mark 1 still stores those elems. so the two marks are equal
    But I think you are in this scene:
    - you have some elems in mark 1, and some others in mark 2
    - you want to do some tasks need mark 1 but want to remember elems in mark 1, too
    There are several ways without affect to mark 2
    1) you can store elems in mark 1 into a variable and restore them later, forexample
    set ElemList1 [hm_getmark elems 1]
    # do something using mark 1
    #restore mark 1:
    eval *createmark elems 1 $ElemList1
    2) store elems in mark 1 into usermark, then restore later:
    *marktousermark elems 1
    #restore mark 1:
    *createmark elems 1 retrieve
    3) store elems in mark 1 into a table, then restore later:
    hm_marktotable elems 1 elem_table_name
    #restore mark 1:
    hm_tabletomark elem_table_name 1
    hm_tableclear elem_table_name ; #free memory
    If you are manipulating on many mark, moving to table is good choice. It's fast, and you can do intersection, union, cut, remove same with mark
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi,
    #restore mark 1:
    #restore mark 1:
    #restore mark 1:
    Thanks for the reply. Sorry for the confussion. Here's what I want to do. Suppose I have some elems in mark ID 1 and some in mark ID 2. And now I want to move elems from mark ID 2 to ID 1, without deleting elems already present in mark ID 1, so that in mark ID 1 I have all the elems. Hope now its clear.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    From point of view of TCL programming:
    • Put mark ID 1 into a list (called List-1)
    • Add items from mark ID 2 into List-1 (by using lappend)
    • Create mark ID 1 from List-1
    Maybe there's better (Hyperworks's) way to do that.
  • tinh
    Oh, so it is simple append it like above post or
    eval *appendmark elems 1 [hm_getmark elems 2]
Welcome!
Welcome!
