H3d files opening
MS_21472
MS_21472 New Altair Community Member
edited April 2023 in Community Q&A
Hi, I use HW and RADIOSS and after Hyperview in a HW window to read h3d file. Since some days, HV ask me to choose a model reader and when a result reader by myself when I want to open the h3d file. I've tried a lot of things and I don't find what I have to choose. Could you help me ?
Welcome!
Answers
  • PaulAltair
    PaulAltair
    Altair Employee
    edited April 2023
    If you choose yourself, does it then work? Or it cannot read the h3d? Sounds like it could be a corrupted results output?
    Are you generating the h3d directly in Radioss (/H3D output requests) or is it being created from your anim files at the end of the run?
    Can you share your model? Or at least your engine file(s)?
  • MS_21472
    edited April 2023
    Hi,
    in fact, until some days ago, I just chose the file in hyperworks/hyperview and it simply opened. Now, I am asked to choose by myself the readers (and I don't know what to choose). It has happened several time that it open correctly by choosing by myself but either, I am not able to do 2 times consecutively the good choice or it is just some kind of hasard.
    I have no /H3D line in the 000.rad file. I simply run the 000.Rad with the compute console and the h3d files are generated. No problem to share the .hm file. As it is too big, I send a link where you can obtain it:
    https://filesender.renater.fr/?s=download&token=b4687211-edbf-4f36-9e97-e558f3ae8a32
    Thanks a lot for your help,
  • MS_21472
    edited April 2023
    Hi again,
    I've downloaded a newer version. There was no problem at  the beginning and now, I have the same problem.
Welcome!
Welcome!
