🎉Community Raffle - Win $25
Join and Win
Error of Solving Flux 3D
User: "Xiaodong"
Altair Community Member
Updated by Xiaodong
Hello,
I have build a 3D Modell of a electrically excited synchronous machine. It has a winding support and end cap at the end of machine. By solving an error happend, 'Non managed error'. I have checked the modell several times. But I can't find the causes of this errror. Could someone help me to solve it? Thanks for your help.
1 - 4 of 41
    User: "Xiaodong"
    OP
    Updated by Xiaodong
    By the way, the error happens after building the electrical loop cut.
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    • When I do check geometry I get an arror message :
    WARNING Geometry is not correct and needs to be corrected. This means that there is a geomtric  problem on your project.
    • Other thing, when I do check physics, Flux display this message :
    The following faces are not used by any volume:
    447  448  449  450  451  452  453  454  455  456  457  458  459  460  461  462  463  464  465  466  467  468  469  470  471  472  473  474  475  476  477  478  479  480  481  482  483  484  485  486  487  488  489  490  491  492  493  494 495  496  497  498  499  500  501  502  503  504  505  506  507  508  509  510  511  512  513  514  515  516  517  518  519  520  521  522  523  524  525  526  527  528  529  530  531  532  533  534  535  536  537  538  539  540  541  542 543  544  545  546  547  548  549  550  551  552  553  554  555  556
    Modification possible using GEOMETRY CONSTRUCT VOLUME.
    For this reason when you try to solve the porject you get the error message.
    Can you try to solve the both problems  geometry and physics and try to solve the project.
    Best regards.
    User: "Xiaodong"
    OP
    Updated by Xiaodong
    Hello,
    Thanks for your answer. The problem you said happens after building the electrical loop cut. Before I built it, I have checked the geometry and physic. There were no errors. I used the automatic create of cuts. So I don't know how can I solve this problem. This problem comes from automatic electric loop cut, doesn't come from my modell.
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    HI,
    Can you send me the Flux project before creating the cut?
    best regards.
