🎉Community Raffle - Win $25
Join and Win
1D Element Type Update
User: "Burner2k"
Altair Community Member
Updated by Burner2k
I had to create stiffeners around an object which has some severe curvatures. To capture the orientation of the 1D elements properly, I had create lots of vectors. Anyways, I used line mesh to create 1D elements.
Not observing closely, the type of element created by using line mesh option was CBEAM while I wanted CBAR (I know the type of elements can be set to desired one during line mesh process but in this case, I mistakenly overlooked it). Now, I want to convert these CBEAM elements in to CBAR.
I know bar->update can be used to accomplish above, but the catch is that orientation needs to be supplied even if I want to update element type only. Like I mentioned above, I have a lot of vectors and it will become tedious to specify vector/orientation for each set of elements just for updating element type. Is there an easier way to do the above in HW 2017.3? I have about 1000 elements for which type needs to be changed to CBAR...
