Error Setting up framework
Hello,
When I try to open up hypermesh I get the following error:
Error setting up framework: can't read 'p_array(Model)':no such element in array
while executing
'raise $p_array($pagename)'
(object'::HM_Framework::NotebookObj1' method
'::HM_Framework::TGF_NotebookClass::ActivatePage' body line 3)
invoked from within
'$nb_obj ActivatePage $activeTabTitle'
(procedure 'p_InstallNotebookTabs' line 36)
invoked from within
(procedure '::HM_Framework::p_FinishInit' line 22)
invoked from within
I uninstalled and then reinstalled Altair on my computer but the problem still persists.
I also tried to remove the hmmenu.st files but that also did not work.
What should I do to resolve this problem?
Thank you
-Eric
Hi Prakash,
My system information is as follows;
OS: Microsoft Windows 10 Home 64-bit (10.0 Build 17134)
System Type: x64-based PC
Processor: AMD A12-9800 Radeon R7
Graphics
AMD Radeon R7 Graphics
Chip Type: AMD Radeon Graphics Processor (0x9874)
DAC Type: Internal DAC(400MHz)
-Eric
Hi Eric,
I had a word with experts,
Please try deleting all setting and temp files and check if that helps.
AMD Radeon R7 is not a supported graphics card. This could be one of the reasons.
Please find the recommended graphics card list here:
Thanks for the update /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
Hi,
Could you please share details of Operating system and graphics you have on your machine?
