Altair RISE
Nominate Yourself Now!
BEAM with variable section
User: "Diogo Ferreira"
Altair Community Member
Updated by Diogo Ferreira
Can i create a BEAM with a variable arbitary section? I mean, i heard that if i use PBEAML properties i can define a variation of the cross section, at least with the standard cross sections (BAR, BOX, BOX1, CHAN, CHAN1, CHAN2, CROSS, H, HAT, I, I1, L, ROD, T, T1, T2, TUBE, or Z), but i wanted to model that beam with a octagonal cross section and with variable octagon size. I´ve been messing with the propertie but so far didnt find anything. Can you help me?
1 - 3 of 31
    User: "tinh"
    Updated by tinh
    Yes, only standard sections are supported for PBEAML
    if you want to assign other sections, use PBEAM
    did you know how to create octagon section? enter 1d>hyperbeam>solid section , draw octagon by lines , select those lines and => create
    OP
    Ok thanks for the answer!
    In PBEAM i can't do variable cross section, am i right?
    User: "tinh"
    Updated by tinh
    Please read PBEAM in optistruct help docs
