Rbe2 problem
Sorry. I haven't solved this problem for a long time.Maybe the rbe2 between the nondesign space(grey) and design space(red) turns wrong.
And it doesn't display which error it is.
Could you help me solve the problem?
Here is my hm.
Hi,
the independent (master) node of an RBE2 element should not be connected to a mesh node.
Create RBE2 elements with independent setting the calculate node.
Thanks for your answer.
But your file version is too high,i can't open it.sad- -
You're welcome.
try importing the attached solverdeck.
No reason to be sad /emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' />
You're welcome.
try with the attached solverdeck.
No reason to be sad
It's so nice of you.
May you happy and healthy everyday!!!
Hi,
