How to use the weld seam in 1D connectors
Dear All,
I want to ask about weld seam application, please see my picture below.
figure1, I want to connect the elements in two components to simulate the weld seam.
figure2,3.I use the 1D connectors seam application to create the seam weld.But there is a node with two REAR which leads to the error when solving the case.The acceptable model is one node connect with one REAR just as figure4.
I want to know how to avoid appearing the condition as figure 3 and to create the correct model as figure 4.
I have some confusing in RBE2 and RBAR, What different between in them?
Best regards,
Little_key
