🎉Community Raffle - Win $25
Join and Win
View Flux mesh in SimLab
Romain BUser: "Romain B"
Altair Community Member
Updated by Romain B
Hi.
At a recent Flux conference, I heard that SimLab has very interesting tools for viewing a mesh and I was hoping to use it to observe the meshing of the air in my 3D models, which is an absolute pain in Flux itself. Is there any documentation on how I can open my meshed geometry from Flux in SimLab?
Thank you in advance!
Romain
1 - 7 of 71
    asoualmiUser: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    In the help of Flux you find all steps that you need to do this operation.
    You follow the steps:
    • In Flux you export your project (step, IGEs… format).
    • Open Simlab and import the (Step, ICES…) file
    • Mesh the device in Simlab
    • Once the device is meshed, you export it
    • In Flux, import the new file that you get from Simlab (project >> Import mesh from a Hypermesh/Simlab/OptiStruct (Nastran) file
    A link to see Simlab mesh export workflow:
    C:\Altair\Flux_12.3\Help\Flux\english\Website\index.html
    Hope this will help.
    Best regards.
    OP
    Updated by Romain B
    Thanl you for your answer.
    However I do not want to mesh in SimLab. I would like to keep meshing in Flux for convenience, but I would like to use SimLab to view the mesh that Flux created. Is this possible?
    Altair Employee
    Updated by asoualmi
    You are welcome.
    Yes it is possible. To do it, one the project is solved:
    1. In data exchange, select export quantity and after select export spatial quantity and formula starting from different types of supports
    2. Flux open a window (see attached PPT file)
    With this method you need to do the same step for each region.
    In the new Flux version (2018), you can do it by selecting all the region in the same file.
    Best regards.
    OP
    Updated by Romain B
    Great stuff! Thank you very much!
    Altair Employee
    Updated by asoualmi
    You are welcome.
    ImanolUser: "Imanol"
    Updated by unknown
    Hello, I also want to export the mesh from flux the same way as Romain. Could you please upload the pptx again? It is not available at this moment.
    Thank you!
    Altair Employee
    Updated by asoualmi
    Hi,
    You will find attached the PPT file.
    Best regards.
