Altair RISE
Nominate Yourself Now!
Query Young's Modulus, Poisson's ratio in Ansys profile
User: "Roshan Shiveshwar"
Altair Community Member
Updated by Roshan Shiveshwar
Hi ,
I am trying to query  Young's Moduls, Poisson's ratio of a material Ansys profile.
The following command doesn't seem to work -
         set E [hm_getvalue materials id=$mat_id dataname=E];         set Nu [hm_getvalue materials id=$mat_id dataname=Nu];
I also tried the following
Is there any way I can successfuly query all the attributes assigned to the material, irrespective of solver setings?
Thanks!
1 - 7 of 71
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Which 'Card image' do you use for your material?  If you use 'MATERIAL', you can try:
     hm_getvalue mat id=1 dataname=MP_EX_VAL2
    User: "tinh"
    Updated by tinh
    Hi
    Query attribute name by
    hm_attributelistall mats 3 name
    @tinh: on my 2019.1 Hypermesh, this command does not work. In the help I see:
     hm_attributelistall  Returns a list of all attribute IDs, names, types or type names for the current template.  Syntax : hm_attributelistall value  Type : HyperMesh Tcl Query  Description : Returns a list of all attribute IDs, names, types or type names for the current template. Inputs  value     The type of list to return. Valid values are:      id - the attribute ID      name - the attribute name      type - the attribute type number      typename - the attribute type string
    OP
    I think he meant
     hm_attributelist mats 3 name
    OP
    Thanks Q.Nguyen-Dai !
    If the profile was Abaqus, I believe I have to use the following:
     hm_getvalue mat id=1 dataname=Young
    Now, since I want to write a code which is profile independent, I am wondering if there is a generic query command. (Atleast for basic properties such as Density, Young's modulus, Poisson's ratio etc.)
    User: "tinh"
    Updated by tinh
    Yes, I am sorry for the mistake!
    I mean hm_attributelist mats 3 name
    @Roshan Shiveshwar if you want a generic way, you will have to filter tokens like E , young in attrib names
    As i see, attrib names of profiles are not same. That means you should store them in a dict.
    OP
    Yes. Even I felt the same. Create a custom library of required attrib names and use them as needed.
