🎉Community Raffle - Win $25
Join and Win
Shell-solid contact error
User: "Uroš Rožič_22105"
Altair Community Member
Updated by unknown
hi all,
I came across an error during the acoustic analysis. the problem seemes to be in FREEZ contact between the solid faces of the acoustic medium and shell faces of the structure. the contact is as such
 *** ERROR # 1904 ***
 SURFACE 13 refers to element 136350 of incorrect type.
If I turn off the contact the simulation works fine
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.fefa01e591c192b224223013c33845e2.png
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.3697493641f646664e6c9bd0d4d50a21.png
SSID are solid surfaces of the solid part and MMID are the shell surface of the shell parts.
thanks for help in advanced.
Regards,
Uroš
1 - 4 of 41
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi @uros
    The issue is coming from a different element type. This is what I can make out from error message.
    Please look for element with ID 136350 and check if that is a compatible element.
    OP
    Updated by unknown
    Is it possible to make shell to solid contact? if not that might be a problem....
    Do you have any idea?
    Altair Employee
    Hi @uros Could you please share the model file with which you are facing issues?
    Altair Employee
    Hello,
    I encountered the same problem. for the master and slave elements of the contact they must be quad type? the type of element indicated in the error message is triangle
