How to resolve ERROR 20029: Cannot find executable file
Hi
I am getting 'ERROR 20029: Cannot find executable file (file path)' for any file I am trying to run. I just updated the Feko version to 2023.1. ( It was 2022.3 before).
I was getting ERROR 2 before updating.
I have Feko 2022.3 on another machine and the same file is running fine in that machine.
I could not find any description for this particular Error code in the documentation.
Can someone please help me to resolve the issue?
Thanks
Vishakha
1 - 2 of
21
Disabling parallel execution worked.
Thanks a lot for your help.
Regards
Vishakha
Hi @Vishakha Pandharpure
Can you check if disabling parallel execution of the solver works?
If you are using CADFEKO to run the solver, the option can be found on the Home tab in the Run/Launch group:
Did you notice if the Updater reported a problem during updating?
Kind regards
Madelé
