ERROR 606
*** ERROR # 606 ***
Element 1 references a PCOMPP card without being referenced
by any STACK card.
Hi,
I'm a novice performing a buckling analysis on a hollow cylinder made of 10 layers of E-glass epoxy. I am encountering this error when i try to run the analysis on optistruct. I am working on hypermesh v11. Please tell me exactly how to rectify this error.
Thank you for your help,
Karthik
P.S. I have attached my file for reference
1 - 3 of
31
There a component with shell elements (PART) which doesn't have plies. .I deleted that and here is the updated model.
Please re-apply the loads and spcs
Hi @k@rthik
Please update the laminate and Plies with STACK and PLY cards, respectively and also there is a part component which is covering the mid-surface. Not sure what it is...
