TCL Force and SPC on local system
Hello Everyone !
I would like to set up a problem on Hypermesh which include around a hundred load cases (in linear static).
To automate it, I found a TCL which 'allows a simple template to be created to define the loadcases; useful for creating large numbers of static loadcases very quickly and easily' (link)
Thanks to a little VBA, I've just succeed in transforming my Excel data base into a readable txt file for this TCL script. And it works.
But my problem is this TCL script only applies my forces (and SPC) on the global system.
Is there a solution, and how can modify the TCL script so that it can apply my load cases on a specific local system (expressed into the .txt for each load cases) ?
If someone can help me to takle this problem, I will be sooo grateful /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
(Because I've never learnt how to program in TCL)
Thanks in advance,
Best regards,
Hervé
