Hello,
The user guide says that a new algorithm for topology optimization is now implemented in OptiStruct called the level set method.
It sounds really interesting and I am curious to use it but I wonder, how does it work? Does OptiStruct decide for its own which algorithm to choose or do I have to manually set it up in some control card? Does work together with SIMP or is it more like a stand alone algorithm?
Are there special features one needs to consider when using the level set method?
Thank you and have a nice day
Hawk
