🎉Community Raffle - Win $25
Join and Win
How to peform FEA on Triangular Mesh derived from an Implicit model?
User: "Ripfumelo"
Altair Community Member
Updated by Ripfumelo
Here i watched a video from "Altair How to" youtube challenge, it says  you can combine a lattice from Implicit modeling and a "B-rep" which creates a triangular mesh then do structural analysis, i can't figure how you apply loads and supports of the mesh, can anyone explain more on this? I've posted the link below
https://youtu.be/QQzOI4hw2kU?si=7nkvx7sjQKoPLUM0&t=256
1 - 2 of 21
    User: "droccaforte"
    Altair Employee
    Updated by droccaforte
    To run analysis on triangular mesh parts you need to choose the SimSolid solver.  That is under File/Preferences/Inspire/RunOptions.
    To control the faces generated during the conversion to triangle mesh you can adjust the break angle under File/Preferences/Inspire/Modeling Space /Discrete Modeling.
    You can see in this example the break angle was reduced to avoid merging the fillets and flat faces.
    User: "Ripfumelo"
    OP
    Thank you very much for your help @David Roccaforte, i learned some advanced stuff in a short space of time.
