🎉Community Raffle - Win $25
Join and Win
Simplify Optimization Results
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all!
Is there a good way to smooth and simplify results that you get from Inspire? My optimization result has so many elements that it is impossible to manipulate. There is no option to use an optimization with 'more material' since that would yield the entire original design space.
Thanks in advance,
Mika
1 - 3 of 31
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Hi,
    Did you try shape explorer in Inspire 2014?See attached screenshot Shape explorer is new feature.
    I hope you would have segregated design and non design region while doing optimization.If not ,please do the same.
    Regards
    Rahul R
    Altair Employee
    OP
    The optimization result I have chosen is taken from shape explorer. Using fit does not yield any workable surfaces. The problem occurs when using 'save to evolve' or exporting the result. When I open it in evolve it crashes due to the amount of elements and SolidWorks does the same.
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    see - http://web.solidthinking.com/evolve_polynurbs_webinar
    In this webinar, you will learn:
    How to import an Inspire optimization into Evolve
    An introduction to the Evolve user interface
    How to use Evolve's polygonal modeling tools to recreate the part as a solid geometry
    How to use the Nurbify function in Evolve to convert polygons into solids
    How to export a solid geometry from Evolve
