Volume Intersection
Hello,
I am currently learning hypermesh. I am trying to mesh an assembly consisting of four parts (same), modelled via Catia. In Catia, I have ensured that there is no intersection between parts in the assembly (Fig 2). When imported, hypermesh approximates the geometry leading to intersection between parts. So, on meshing , some elements cut each other.
I have tried Autocleanup for the geometry without success. How do I ensure that the parts do not intersect?
Thanks in advance.
(Kevlar Fabric)
(Crossectional View - made to just touch via constriants in Catia)
Volume Intersection Observed - Dotted white line of a part passes through another part
Hi,
Did you import *.CatPart file or IGES/STEP file?
