Im doing an impact analysis for a single component of a car. I want to contsrain one end of the component ( side sill) and apply a velocity to this component. What is the right way to make one side of the component rigid?
I have another question regarding penetrations. The penetrations are not visible, I could use the autofix tool but the mesh gets distorted! Is there anyway i can fix this! I have attached an image of the failed elements!
Like you mentioned last time , about unchecking self penetration, i dont seem to find that option. This is what i use to check the penetrations and intersections.
Hi vishruthdilip
Check the tutorial RDT 3530 from Radioss help and the attached video.
Thanks
