Selection of components as per user
BG913
BG913 Altair Community Member
edited October 2020 in Community Q&A
Hi,
Is there a way to select components in the order the user selects ?? I checked for *createlistpanel but it isn't applicable for components, and hm_getmark always gives a result of a list which is ascending order only.
Welcome!
Answers
  • tinh
    tinh Altair Community Member
    edited March 2019
    Why do you need that?
    A workaround is : select elem list, and then retrieve component list that store them.
    Directly, I think we can hook a callback with event graphic_selection_changes
  • BG913
    edited March 2019
    Actually for this code I really want it as a component selection rather than element. That way the user knows the entire range of selection he/she is making. Like as much as possible I want to avoid the element selection as it would be not as appealing to the user.
    And I'm sorry, I don't know much about graphic selection changes, haven't explored those options.
  • Pandurang
    Pandurang Altair Community Member
    edited March 2019
    please Try this:
    variable list1
    proc framework args \
        *createmarkpanel comps 1 'Please select the components ';
        hm_framework registerproc getorderedcomps graphics_selection_changed;
       *clearmark comps 1;
    proc getorderedcomps args \
        variable list1;
        lappend list1 [noIntersect;];
    proc noIntersect args \
        variable list1;
        foreach item [hm_getmark comps 1] \
            if {$item in $list1} \
                continue;
            } else {set comp $item};
        return $comp
    framework
    puts $list1
  • tinh
    edited March 2019
    If user deselect a comp you need to lremove item from list1
  • Pandurang
    edited March 2019
    BG913
    Even if deselect component this will take care of it.. Thanks To @tinh for suggestion...
    Please try this updated one:
    variable list1
        *createmarkpanel comps 1 ' ';
        variable list1;
        set value [noIntersect]
        if {$value != ''} \
            lappend list1 $value ;
        variable list1;
        set marklist [hm_getmark comps 1];
        foreach item $marklist \
                continue;
        if {[info exist comp]} \
            return $comp
        } else \
            foreach item $list1 \
            if {$item in $marklist} \
                continue;
            } else \
                set list1 [lremove $list1 $item]
    framework
    puts $list1
Welcome!
Welcome!
