Meshing problem
I designed a narrow beam antenna(Diameter is approx. 20 times lambda ) in HFSS and imported in FEKO. The design is very complex as it contains mechanical parts also like comparator. Due to very complex design, it shows meshing error. How we can rectify meshing problem? I also need to know about 'SIMPLIFY' option in feko? Is it helpful in my case or not? Please help...
Thanks in advance.
1 - 1 of
11
Vikas,
Sometimes when exporting CAD from a 3rd party and importing into FEKO, translation errors/tolerances could cause unexpected problems, such as meshing issues.
We have found often the step format works best. Please try this if you have not already. FEKO can import a variety of CAD formats.
