🎉Community Raffle - Win $25
Join and Win
Rod Stability
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Good evening,
I am working on my aerospace engineering final project consisting of a flight control system. As you can see from the picture attached, I am using motionview to model a series of  rods connected with several joints.
My teacher asked me to write a script to make hyperworks automatically analize rod's stability. In particular, the following expression should not exceed a known value:
F = (pi)^2 E I /(L^2)
where 'L' is the lenght of the singular rod and 'I' is the minimum moment of inertia.
To sum up, I need motionview to read the lenght and the moment of inertia of each rod and to check the value of 'F'
This is the first time I use motionview for this scop so I don't really know what I should do.
I would be greatful if anyone could help me
thank you in advance for your help
