Altair RISE
Nominate Yourself Now!
How to create a simple loop?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I would like to create a simple loop however I'm not very good in programing... My script is like this but instead of '...' I would like to create a loop which would work till I press return or escape. Is there any simple method?
*createbutton(5, 'Triad', 18, 0, 4, BUTTON, 'Create Triad', 'macroTriad')
*beginmacro(macroTriad) <cr>
*createlistpanel(nodes,1,'Select nodes') <cr>
*createelement(103,1,1,1) <cr>
*endmacro() <cr>
Kind regards,
Lukasz
1 - 8 of 81
    Altair Employee
    OP
    Hi,
    I don't understand what you want exactly, a simple loop looks like this ...
    *createmarkpanel elements 1 'Select elements ...'
    set element_mark [hm_getmark elements 1]
    foreach eid $element_mark {
    tk_messageBox -message 'Element : $eid'
    or
    set stop 0
    while {$stop == 0} {
    # your code here
    set stop 1
    Regards,
    Mario
    Altair Employee
    OP
    hello...
    i would like to make a script to delete assemblies and sub assemblies in one action... that's need a loop script..please help me
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    Use while loop:
    Condition is 'remain emptied assem' use *EntityPreviewEmpty and hm_marklength to check that condition
    Body is 'delete them' , use *deletemark
    Altair Employee
    OP
    can you give the full script for me. because i dont know how to make it
    Altair Employee
    OP
    Hi MEIYARASU19
    Refer the example script from  below link
    https://connect.altair.com/CP/script-list.html
    User: "tinh"
    Updated by tinh
    If you don't know how to make script I recommend you to learn tcl programming first, not to make tons of questions.
    Tcl is easy.
    Altair Employee
    OP
    Tcl is easy.
    Thank you
    Altair Employee
    OP
    Hi MEIYARASU19
    Thank you
