Precision in OptiStruct results
Guys, how to increase number of digits after decimal point in OptiStruct result files. For example, if I request using command
stress(OPTI)=all
I receive the stress in this format: 7.43321E+01, but I want to get something like this 7.433211241227E+01 May there is some kind of command which can control precision of output number. Thank you!
1 - 2 of
21
Hi,
Information about How to change the precision of the value displayed in a note is given in the attached document.
Hope it helps.
Hi, did you solve your precision problem? I would appreciate if you share in case you solved it.
Thanks!
