parametric optimization
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Has anyone done parametric optimization in optistruct-hyperstudy?
i want to do that crossbar can slide through frame. I defined morph volume. But i don't know how can i connect desvar and morph volume?
Is it right way? i have seen just size/shape configuration, so it's not my way.
i had tryed to save volume and looked for txt file. it doesn't consist elements, so i can't use it in hyperstudy.
could anyone explain me how does it works?=)
Thanks.
1 - 16 of 161
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    First create desired shape using morphing (Morph volume/domain handle approach).Once the morphing is done, you can export shape variable from Hypermesh to HyperStudy.Refer HS-1021 and HS-1025 Tutorial.
    Altair Employee
    OP
    @Rahul R i understand, but issue is in creating shape.
    i created morph volume. and how to create shape from volume?
    You can refer HyperMesh Morphing Tutorials for Morph Volume concept.
    HM-3550: Morph Volume
    Altair Employee
    OP
    ok.
    But how does it help me to create 'shape' for assigning  desvar? i don't understand you @Rahul R. i'm just newbie in Altair Software.
    Whenever you execute morphing operation using any approach(Domains/Handle,Morph volume or Map to geometry),you have option to save those shape as nodes perturbation.Then you can use those shape as design variable for optimization.
    Altair Employee
    OP
    i did it, but i should move it. if i do not move it shape will not be saved. it was my problem. i had moved it to 0.001 mm and saved.
    thanks.
    Can you share the .hm or fem file to have a look ?
    Altair Employee
    OP
    ok. but not now. thank you for your help offer. Can i take it latter? i try to do optimization model. if i have some complications with it i will send model to you, ok?
    Altair Employee
    OP
    @Rahul R
    I’m interesting in 2 moment now:
    1.       How to interpret this moment
    but as you can see in result:
    I think it’s not 10 mm…=)
    2.       I want to do model that aim will be frame stiffness. So I am just solving 3 case of solution. But I want to solve 10,20,30… etc, and HyperStudy should look at SPCF MX at grid 479017. I don’t know how does it realize? It is very interesting work for me. I try to vary crossbar position and it thickness.
    Regards
    Altair Employee
    OP
    i have solved particulary second question.
    but i had some problem with values. HyperStudy doesn't like it=( Why does it so?
    how to fix it?
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.9f1763597ce7fd40f33418a164ceeceb.png
    It would be nice if you can share .xml or .hstx file of HyperStudy to take a quick look.You can use dropbox available in my signature.
    Altair Employee
    OP
    Altair Employee
    OP
    i hope i fix it.
    i haven't solved question about crossbar displacement. (how to define displacement of crossbar, if i assign for down boundes(-10), initial(0) and upper bound(10) it will look larger)
    and i want another approach. i do sweep, but it grows linear my values. could you give me advice, @Rahul R?
    Altair Employee
    OP
    For bound you have option to change the value as per your requirement.Refer below post.
    Altair Employee
    OP
    Thanks for the good ideas to bring it. I know a lot more. :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    พนันบอลออนไลน์  : J
