🎉Community Raffle - Win $25
Join and Win
Can we drag normal direction elements?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I know we can use drag to drag element from x,y or z direction.
But can we drag normal direction elements?
I have a circle and I want it to plus the diameter, so I need to drag it's normal direction elements.
How should I do this.
Because I change here, but it can't show what I want.
1 - 13 of 131
    Altair Employee
    OP
    Hi LKZ,
    It is not possible to drag elements in the normal direction. Instead, you can use Scale option in the Tool panel.
    Thank you
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    @LKZ To try this method: project (by duplicating) boundary nodes to new circle with option 'line normal'. And then create new mesh with method 'ruled' by defining two list of nodes.
    Share your HM model?
    Altair Employee
    OP
    @Q.Nguyen-Dai I can't completely know
    Do you have any file about that.
    Really thanks.
    Share model?
    Altair Employee
    OP
    @Q.Nguyen-Dai Thanks to your reply.
    Here is the model and I want to grow the normal direction of elements.
    File
    Find face at outer radius then make scale. I take a factor of 1.2 as example.
    <?xml version="1.0" encoding="UTF-8"?>screenshot_88.thumb.png.5bbe1985668e8e483bb56e38f1b6a598.png
    We got two surfaces. Make solid map by using '3D' => 'linear solid':
    <?xml version="1.0" encoding="UTF-8"?>screenshot_89.thumb.png.4ff44c750ccae3ab7a4799e47d43728e.png
    And finally:
    Here's HM model:
    HTH,
    Altair Employee
    OP
    @Q.Nguyen-Dai Really thanks for your help.
    Because I used the HyperMesh 2017.2, I think at the last step my interface is different from you.
    My last step is like this. I think it will be helpful for other person.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.0d7743d1eee16a63f79d6c7c3e82be57.png
    And at the last I can finish my model. Really thanks!
    I think it's have some problem about although it can drag the normal element.
    We just can drag one layer element at once, I think it will spend every user many times.
    Altair Employee
    OP
    Hi
    Change the element size option to Density. And give density 2.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.ca94e196a244a4eb393c5608a12af9bf.png
    Thank you
    Altair Employee
    OP
    @Premanand Suryavanshi Sorry I reply so late.
    Really thanks for your help. I will try it.
    Altair Employee
    OP
    @Q.Nguyen-Dai Hi
    When I use the scale, I find a problem about if I want to scale for the distance.
    Can we do that? Because when I set the scale factor, I can't catch the value correctly.
    And it can't grow the size what I want.
    Do you have this solution? Really thanks.
                                         future external radius
    The scale factor = --------------------------------------------
                                         current external radius
    Altair Employee
    OP
    @Q.Nguyen-Dai Thanks for your help.
    I have a last question.
    If I have many layers about the model, and I want to separate them.
    But when I use Tool→Organize→element by faces it can't let me pick one layer of elements.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.0230a3511f6fb8d4e7eff2d01772081d.png
    How can I quickly pick every layer of them and where is my wrong?
    Really thanks.
    User: "tinh"
    Updated by tinh
    Hi, solid elems cannot be selected 'by face'
    with first layer, try 'find attach' (shift F5): select nodes 'by face', then find elems attached to those nodes.
    once you moved a layer to new comp, you can select it 'by collector' and select next layer 'by adjacent', then subtract 1st layer from selection also 'by collector'
