🎉Community Raffle - Win $25
Join and Win
BUGS in HyperWorks TCL commands
User: "tinh"
Altair Community Member
Updated by tinh
I encountered a bug in hyperworks tcl command
Client                          Version                          Command                                                             Bug Information
Hypermesh                12                                   *findmark elems 1 1 1 elems 0 2                        this command did not add elems of mark 1 to mark 2
1 - 2 of 21
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    it works for me... the findmark function will return the attached elements to the provided elements. If you need the original elems, append them to the mark.
    set elemIds <list with given elems>
    hm_createmark elements 1  $elemIds;
    *findmark elements 1 1 1 elements 0 2;
    hm_appendmark elems 2 $elemIds
    set elemList [ hm_getmark elems 2 ];
    puts $elemList;
    Remember that the list contains the HM elems ids, not the solver elems ids. To get the solver ids use:
    hm_getsolverid2 elems $elemIds
    User: "tinh"
    OP
    Updated by tinh
    I encountered bugs in hyperworks tcl command
    So you should care about these
    Hypermesh          12                    *findmark elems 1 1 1 elems 0 2                     this command did not add elems of mark 1 to mark 2 regardless the specified option
    Hypermesh          12                     hm_getthickness comps $CompId                 If component name starts with '\' then this command return 0.0 regardless actual thickness
