🎉Community Raffle - Win $25
Join and Win
Hypermesh : surface cleanup
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hallo,
what's the best possible way to remove these small counters protruding from the surface, in hypermesh ?
attached is the picture. (its a circular rim and these contours are all through the surface)
thanks in advance!
<?xml version="1.0" encoding="UTF-8"?>rim.thumb.PNG.ead7e9ad35ee4cb9b231c7a951
Palash
1 - 3 of 31
    Altair Employee
    OP
    For complicated geometry, it's better to use CAD software (PTC Creo, Catia, Solidworks,...)
    You can do some simplification within HM, but it's costly (working time).
    Altair Employee
    OP
    You can easily delete these protrusion using mask and delete tools (Delete the surface also on which protrusion are);  then create surface using ruled (geometry>surface>Ruled). It will be the quickest way to simplify.
    Altair Employee
    OP
    Another workaround is to trim the solid with a circular line with a diameter=  total diameter of the component - thickness of protrusion. This works only if the component is symmetric and circular.
    If the geometry of the component is complex, better go with a traditional CAD tool instead as Q.NGUYEN-DAI  suggested.
