Wing rib assembly to wing skin
Hi guys,
do you have any ideas how to model an assembly with multiple composite components? As shown here http://www.rowlandcarson.org.uk/aviation/europa_435/_images/dscn1733.jpg I want to model ribs which are bonded to a specific surface. Do I have to do that with sub-laminates? Are there any tutorials for sub-laminate modeling?
I am using HW13.0
Thank you in advance.
Hi Prakash,
thank you for the presentation. I tried to realize the sample with a T-beam. The lay-up can be compared to the example, which can be found in the HW-Help (XXXX/Altair/13.0/help/hwsolvers/stack.htm?zoom_highlightsub=ply example 2). I have attached the .fem-file of my model and a short summary of the lay-up.
Actually, I have 4 sublaminates and an interfacelaminate to 'bond' all sublaminates together. I have assigned PCOMPP-property to all mesh-elements. After modeling, I have started a short analysis of the beam but the following error-msg appeared:
*** ERROR # 640 ***
STACK 5 is incorrectly or ambiguously defined. This could be
due to disconnected substacks, duplicate interfaces or inconsistent
interfaces orientations. Please verify the substacks and interfaces
thoroughly.
Can you give me a feedback with hints to solve this problem? Another question is, does the geometry have to be 'connected together' for modeling a laminate with sublaminates?
Best regards
Wiko
Hi Wiko,
Check this link below:
http://www.altairuniversity.com/wp-content/uploads/2012/06/Composite_Pre_Postprocessing.pdf
