RBE2 Application
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Dear All,
I want to ask about RBE2 application, please see my picture below.
I have a simple plate, and I want to give constraint on 2 holes on top, and forces (160kN on both hole or 80kN each hole) on 2 holes on bottom
Why my simulation result (stress & deformation) totally different?, because in my opinion, case on the problem 1 and problem 2 are same....
Am I miss something?
Best regards,
Iron_Man
1 - 18 of 181
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    To me it should give different results.Point of load (distance)is varying.Any specific reason for using only specific nodes for creating RBE2/why not selecting all nodes of hole?
    Altair Employee
    OP
    @Rahul R,
    Thank you for your response, you said 'To me it should give different results.Point of load (distance)is varying' could you telling me more detail about it? or you have reference documents to understand about it?
    'Any specific reason for using only specific nodes for creating RBE2/why not selecting all nodes of hole? '
    I use RBE2 on half of hole to describe shaft contact area.
    Thank you,
    Altair Employee
    OP
    Hi @Iron_Man59
    I think in second case you will see a moment around the SPC point and your displacement results will be huge compared to first one.
    Instead leave SPCs as in case one and apply force/load as in case 2. Your results should match.
    User: "tinh"
    Updated by tinh
    No no, I think it is due to another reason...
    assume X is horizontal direction
    in case 1, 2 holes with force can have X deformation
    but in case 2, they are impossible. rbe2 is similar to a rigid bar which constrained x deformation. so result of 2 cases will be different. could you check case 2 deflection is lower than case 1?
    SPC and Force are same, but structure stiffness are different
    Altair Employee
    OP
    Dear All,
    @Prakash Pagadala,
    'I think in second case you will see a moment around the SPC point and your displacement results will be huge compared to first one.'
    No, the displacement on problem 1 is bigger than problem 2, please see my picture below.
    'Instead leave SPCs as in case one and apply force/load as in case 2. Your results should match.'
    What the problems that should be compared to your statement above? Problem 1 VS Your statement or Problem 2 VS Your statement?
    @tinh,
    'could you check case 2 deflection is lower than case 1?'
    As what I mention above, YES, the displacement on problem  is lower than problem 1
    All,
    Please see my actual problem below, maybe you could give better solution how to model it on hyperworks,
    Thank you,
    <?xml version="1.0" encoding="UTF-8"?>Problem1 VS Problem 2_Displacement.PNG
    Altair Employee
    OP
    Here are my three cases:
    Altair Employee
    OP
    @Prakash Pagadala,
    I see that the result on problem 1 (left picture (biggest one)) is similar with the result on problem 2 (right picture(top)), my question, which is better to use?
    if you have reference to study about that problem above please share to us.
    thank you
    Altair Employee
    OP
    My case here is different. But I think in case 2 there is some local stiffness due to rigids.
    User: "tinh"
    Updated by tinh
    Hi.
    Just use RBE2 at SPC positions
    with LOAD positions => use RBE3 to eliminate over-stiffness
    Altair Employee
    OP
    @Iron_Man59
    Few questions:
    1) Why only half of the hole is constrained and loaded?
    2) Can you use RBE3 for loading?
    Altair Employee
    OP
    Hi @tinh,
    I never used RBE3 before, please give me guidance to use it (what is RBE3?, what is the differences with RBE2?, when to use it?, etc)
    Thank you
    Altair Employee
    OP
    In short,  RBE3 does not add stiffness like RBE2
    Altair Employee
    OP
    @Prakash Pagadala,
    Yes, I know about it, BUT I need the information how to use RBE3 correctly!!!
    Any reference?
    Thank you
    Altair Employee
    OP
    Hi,
    Please go through this webinar on using RBE's with examples. Hope this will be helpful.
    Altair Employee
    OP
    Hi @George P Johnson,
    Thank you for sharing the video, but unfortunately the video is broken.
    I can not play it.
    Please share another link.
    Thank you,
    Altair Employee
    OP
    Hi,
    This video is working fine at my end. I just played the same in GOM player. Once the file starts click the video player screen and it will start.
    Please try and update
    Altair Employee
    OP
    I've update my windows media player and re-download your video, but the video is still error to play.
    Altair Employee
    OP
    Hi,
    This seems very strange!!!...The same worked for me in Windows Media Player.
    I'm reattaching the file once again. This is in .swf format. Recommend you to download GOM player and try playing the same.
