Altair RISE
Nominate Yourself Now!
TCL script : need help
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Dear Sir,
I am Begineer to TCL scripting. need small help
actually i am developing a small script i.e
lets say i have few components with naming like COMPNAME_MATNAME_Txx.  this script will read COMPNAME & and it will create a PSHELL property with thickness (xx) with same name. and also it will read MATNAME and it will create material with same name.
Q) i want split the original compname & matname and assign to some variable like this :    set thickness [string trimleft [lindex [split $comp_name _] end] t]
how to do this one?
I have done with simple commands like (string range).please refer below picture
Thank you,
Regards,
Gopi
1 - 7 of 71
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    Suppose there are only 3 '_' in the name.
    regexp -nocase {^([^_]+)_([^_]+)_t(.+)$} $comp_name = CompName MatName Thickness
    Altair Employee
    OP
    Hi
    Thanks for your quick reply.
    yeah i want to split according  '_ . (underscore)
    but how to assign to different variable using above logic?
    i want to do like this:  set compname xxxxxxx(logic)
                                          set matname xxxxxxxx(logic)
    getting some error please check below pic
    User: "tinh"
    Updated by tinh
    Do you copy and paste my command?
    :rolleyes:/emoticons/default_rolleyes.gif' title=':rolleyes:' />
    User: "tinh"
    Updated by tinh
    Please type it as it is, from regexp to the end, don't miss any character, you will get CompName MatName and Thickness
    Altair Employee
    OP
    Hi ,
    I tried with below command but did not get comp mat and thickness names.
    can suggest me another method to split this (ex:comp1_mat1_txx). I want to split this onto three different parts i.e comp1, mat1, & xx (thickness value)
    thanks in advance
    User: "tinh"
    Updated by tinh
    You can use split, lassing, string range commands to do it.
    Regexp will do it in 1 invocation.
    Altair Employee
    OP
    Yeah it is very useful command. Successfully done.
    Thanks @tinh
