1 - 7 of
71
Hi VigneshKPV,
There is some defect in the model (Shown in below image). Therefore, you are not able to import the solid as it is in HyperMesh.
So, you perform equivalence of surfaces and go to solids panel and create bounding surfaces (shown below). Your solid model will be created.
Thank you
Hi VigneshKPV,
Please can you share the model?
Thank you
