Altair RISE
Nominate Yourself Now!
I wanted to add different properties to each element to represent functionally graded materials. I had to create components for each property and hence material. Is it possible to create property table with each element having different material prop
User: "Adeline War_20893"
Altair Community Member
Updated by Adeline War_20893
1 - 7 of 71
    User: "Payal Pawar_20288"
    Altair Employee
    Updated by Payal Pawar_20288
    Hi
    Please let me know what Altair product are you using so that I can direct your question to the proper forum.
    OP
    Hi
    @Payal Pawar I am using Altair Hyperworks 2019. Thank you
    User: "Nguyễn Minh Vọ_21172"
    New Altair Community Member
    Updated by Nguyễn Minh Vọ_21172
    I am interested in this issue , if you have the answer please mark it for me . Thank you
    OP
    Hi
    I am using Altair 2019.
    Thank you
    OP
    Hi
    Hello! Can I get a solution for this?
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    hi, unfortunately I don't have a quick solution for that. You will need to assign different props/mat per element.
    If you have some kind of control over the IDs, maybe a TCL script could help you to get this done easier.
    OP
    Is it possible to assign material property to the element and not to the component in Hypermesh. I am not sure if that is feasible?
