Altair RISE
Nominate Yourself Now!
How to execute a tcl script in an existing HM session whose PID is known
User: "Saumya4Mishra"
Altair Community Member
Updated by Saumya4Mishra
Hi all,
I wanna run some script in my already opened HM session. Is there any way we can access the HM session and execute the tcl script?
NOTE:  I have the HM Session PID where I wanna run the script
Regards
Saumya
1 - 4 of 41
    User: "tinh"
    Updated by tinh
    Yes, your hm session must work as a server. Use dde or socket command
    OP
    hi tinh
    can you kindly explain through an example?
    User: "tinh"
    Updated by tinh
    https://community.altair.com/community?id=community_question&sys_id=ae5688f61b2bd0908017dc61ec4bcb52
    Refer above.
    In your case, this way may be simpler:
    Your hm session (eg. with pid 1234) must pre-run a timer (write it in c:/users/name/hmcustom.tcl)
    That timer checks a file eg. 1234.tcl
    If file existing, source it, then clear the file!
    So everytime you want to excute a script, put it in 1234.tcl
    A such timer:
    proc ::p_MonitorFile {{path {}}} {
       set path_ $path
       after cancel [list ::p_MonitorFile $path_]
       if {$path==''} {
          set path [file join $::env(HOME) [pid].tcl]
       if {[file exists $path]} {
           catch {source $path} err
           file delete $path
           puts 'Executed $path got $err'
       after 3000 [list ::p_MonitorFile $path_]
    OP
    hi tin
    That works . Thanks for the help
