🎉Community Raffle - Win $25
Join and Win
How to select a set of nodes on a vector defined by N1, N2, N3 and basepoint?
User: "Sathish_21542"
Altair Community Member
Updated by Sathish_21542
If N1 is 100(node id)/ N2 is 101(node id)/ N3 is 102(node id).... Basepoint is 'userdefined', tolerance 0.1 / normal to plane
how to write a code to select a list of nodes falling on the defined vector?
Thanks in advance!
1 - 4 of 41
    User: "vipin_22401"
    Updated by vipin_22401
    Hi sathish,
    you can use 'on plane' option in *createmark.
    for example if you have base coordinates and vector normals,
    *createmark nodes 1 'on plane' $baseX $baseY $baseZ $normalX $normalY $normalZ 0.1 0 0
    hm_getmark nodes 1
    OP
    Hi Vipin,
    Thanks for the reply!
    I have came through this 'on plane' option. But the problem is I have the input N1, N2, N3 and basepoint only. Can you help me with the codes for extracting base coordinates and vector normals from the input?
    Thanks!
    User: "vipin_22401"
    Hi Sathish,
    you can find a proc for vector normals from 3 nodes in following thread:
    https://community.altair.com/community?id=community_question&sys_id=0396447a1b2bd0908017dc61ec4bcb47
    use the proc to find vector normals:
    set vecNormals [NormalFrmPlane $N1 $N2 $N3]
    set baseCords [lindex [hm_nodevalue $baseNode] 0]
    substitute these values in *createmark command :)
    *createmark nodes 1 'on plane' {*}$baseCords {*}$vecNormals 0.1 0 0
    OP
    Hi Vipin,
    Thanks!
    Its working
