/profile/50079-ankitmehta11/?do=hovercard' data-mentionid='50079' href='<___base_url___>/profile/50079-ankitmehta11/' rel=''>@Ankitmehta11 Did you got the results considering the rotation of the disc?? I am also working on similar kind of analysis. looking for some inputs/guidance
Have you take a look at these tutorials from OS documentation?
First you impose a clamping force, then apply a small rotation and then run complex modal analysis.
If that's what you mean by roatation, it is all there in this tutorial.
Thanks /profile/97129-adriano-a-koga/?do=hovercard' data-mentionid='97129' href='<___base_url___>/profile/97129-adriano-a-koga/' rel=''>@Adriano A. Koga I referred OS-T_1371 and with the help of Altair support I successfully run the model.
Apply the angular displacement carefully ! The results in optistruct depend on the angular displacement (in the second step) which is not the case in the CEA formulation ...
HI,
Please refer to OS-T: 1371 Brake Squeal Analysis of Brake Assembly tutorial
