🎉Community Raffle - Win $25
Join and Win
Why is the definition of TSTEP necessary for Nonlinear Direct Transient Analysis?
cfuserUser: "cfuser"
Altair Community Member
Updated by cfuser
Dear Support-Team,
I am currently working on a Nonlinear Direct Transient Analysis to be solved with OptiStruct. I have read in a variety of sources that for this kind of problem  NLPARM and TSTEP load collectors must be defined. I have also read that some entries made in NLPARM will override entries written into TSTEP. If this is so, why do I have to define a TSTEP load collector in the first place? Further, is my assumption correct that NINC-, DT-settings in NLPARM (also in NLADAPT and NLOUT) refer to time incrementation when performing a Nonliniear Direct Transient Analysis??
I'd be very grateful for your Help!
Cheers!
1 - 4 of 41
    tinhUser: "tinh"
    Updated by tinh
    They (software developers) don't merge those 2 cards because some features just need one of them.
    It is about data organization, i think so.
    OP
    Updated by cfuser
    First of all, thanks for your reply tinh!
    I understand what you are getting at. Still, I'm not quite clear about one thing. In TSTEP I am defining ' time step parameters for control and intervals at which a solution will be generated and output in transient analysis' (quote from OptiStruct Help-webpage on Bulk Data Entry TSTEP). I understand what the different parameters are meant to do (N, DT, NO and so forth). But when I define them and leave similar parameters in NLPARM blank intentionally to avoid overriding the solver won't stick to the defined parameters. For example, when I define N=1000 and DT=0.001 in TSTEP I would expect to have 1000 increments solved by OptiStruct. The Out-file shows, that a lot less increments are actually solved. Even when I put DIRECT=yes in NLADAPT to specify fixed increments.
    Thinking about it, I still have a lot of stuff I am not sure about regarding HyperMesh/OptiStruct.
    Maybe somebody can clear things up for me? :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Please refer the material shared in below post for Nonlinear Direct Transient Analysis.
    https://community.altair.com/community?id=community_question&sys_id=5266003a1b2bd0908017dc61ec4bcba1
    OP
    Updated by cfuser
    Hello Rahul,
    thank you for your reply.
    Cheers!
