Sum-SPCF Problem
Dear Everyone, I have a problem with Sum-SPCF.
Basicly, I have already export SPCF for X-dir (.csv). Next step, I calculate sum all value by ∑SUM function in exel.
But this value is rather different from OptiStruct output . I don't know my method (make ∑Sum in excel) is RIGHT or WRONG?
Best Regard
Because security so I can't show picture at here.
I restraint SPC ( all dofs) and apply force 500N for shell plate.
I think according to a arbitrary direction, only plus all SPCF value of BCs grid is OK.
But It's a difference./emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />
Thank you for your hint. I have already found out reason to lead this mistake. I used WPS software to calculate SUM value ( not Microsoft Office)
All number in format scientific will be lose E^x. So my result is not correct. I'm very supprise for this.
Thank you so much. /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Thank you so much.
Aiie /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
If you does not have Microsoft Office, try LibreOffice, it's OpenSource Software and it works very well, including with DOCX, XLSX, PPTX files.
Dear /profile/43398-qnguyen-dai/?do=hovercard' data-mentionid='43398' href='<___base_url___>/profile/43398-qnguyen-dai/' rel=''>@Q.Nguyen-Dai /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Thank for your instruments. I'll try this software. If possible, I will request IT install in my PC.
WPS software is Chinese soft. It's terrible for using calculate numbers. /emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />
Once, Thank you so much /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
I need some pictures to understand your problem from point of view of mechanics (loads,BC,...)
