🎉Community Raffle - Win $25
Join and Win
Error rectification in Motionview as a part of Flexbody preparation
KVUser: "KV"
Altair Community Member
Updated by unknown
Hi,
      I have started exploring motionview just recently for MBD simulations. As part of it, I have tried to import .fem and h3d files through flex prep as part of flex body creation. But, it is showing the following error. Kindly help me rectify
1 - 4 of 41
    PrafulUser: "Praful"
    Altair Employee
    Updated by Praful
    Hello K V - Would you be able to share the files, so that we can have a look at it ?
    Thanks
    Praful
    Altair
    KVUser: "KV"
    OP
    Updated by unknown
    Thanks
    Praful
    Altair
    Thanks for replying Praful. But, I am sorry. These files are official. Sharing them would not be possible.
    Altair Employee
    Updated by Praful
    Hello KV - I understand.
    Without the files it would be hard to figure out.
    I can only speculate. Likely there was an earlier flexbody which was used and a connection to the flex body could have referring to a node ID 1 in that flexbody. Then the flexbody was likely changed which does not contain that ID.
    Could you try going into the Nodes dialog in the Body panel of the flexbody and use the Find button to update the nodes ?
    In case this helps, I am the Program Manager for MotionView.You may send the files to ppraf@altair.com. The files will be handled in a confidential manner and deleted from system once your issue is resolved.
    Regards
    Praful
    KVUser: "KV"
    OP
    Updated by unknown
    Regards
    Praful
    Sure Praful ji. Will share
