Altair RISE
Nominate Yourself Now!
ERROR 14: Missing property
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I am having problems with my 3d mesh in that i keep getting error 14 which i believe has to do with my property card image. My mesh is made from a solid map mesh and I am using psolid as my card image. Is there another card image to use with a solid map mesh?
1 - 7 of 71
    Altair Employee
    OP
    Hi user,
    The property card image for solid element is PSolid. Please make sure that the property is assigned to the component. Also ensure that there are no shell elements in that solid component.
    Altair Employee
    OP
    Hi @potatoisnice
    Can you check if there are any 2D elements in your model?
    Since you have 3D elements, PSOLID works. but not sure why you get this property error.
    Just to make sure check if there are any 2D elements, if possible paste the entire error message.
    Altair Employee
    OP
    I had a shell element that I didn't notice though the problem still isn't solved. My entire error message is as following:
     **                        OptiStruct 14.0.220                         **
     **                  Design and Optimization Software                  **
     **                   from Altair Engineering, Inc.                    **
     **             Windows 8 Workstation  (Build 9200)  SHAKA             **
     **          4 CPU:  Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz          **
     **                        CPU speed  3400 MHz                         **
     **                    9715 MB RAM,  18764 MB swap                     **
     ** Build tag: 0824300_9433140_Ce64RBW8UH12M:119032-000  4000020004001 **
     **  COPYRIGHT (C) 1996-2016                 Altair Engineering, Inc.  **
     ** All Rights Reserved.  Copyright notice does not imply publication. **
     **         Contains trade secrets of Altair Engineering, Inc.         **
     ** Decompilation or disassembly of this software strictly prohibited. **
     *** OptiStruct defaults set from:
       install config file: Z:\Altair\/hwsolvers/optistruct.cfg.
     NOTE # 9199
     MSGLMT=STRICT is active, all messages will be printed.
     You can suppress some less important warning messages by use of
      MSGLMT=BRIEF or UNREF (in config file or in the input data).
     *** ERROR 14: Missing property #    1 referenced by  CTRIA3 # 14.
    (HERE I CUT OUT ALL THE ERROR MESSAGES AS THEY WERE THE SAME)
     *** ERROR 14: Missing property #    1 referenced by  CTRIA3 # 3414.
     *** More of ERROR messages # 14 were suppressed...
     *** Errors with missing, incorrect or duplicate IDs found 451 times.
     MAXIMUM DISK SPACE USED                                     1 MB
    COMPUTE TIME INFORMATION
     EXECUTION STARTED                         Wed Oct 05 23:04:26 2016
     EXECUTION COMPLETED                       Wed Oct 05 23:04:28 2016
     ELAPSED TIME                                         00:00:01
     CPU TIME                                             00:00:01
     *** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
                            ***** END OF REPORT *****
     For Useful OptiStruct Tips and Tricks, go to the URL:
    http://www.altairhyperworks.com/tips.aspx
     Following warning messages appeared too many times
     and were suppressed:
          14
     Total of 251 repeat error message(s) were suppressed.
     To see more messages use 'MSGLMT' control card in the data or config file.
     There were 451 error messages during input processing.
      The first message is repeated below:
    Altair Employee
    OP
    Hi,
    There are CTRIA3 elements (2D elements). Please delete those (if they are not a part of the model) and check again.
    Altair Employee
    OP
    How would I check to see my 2d elements. I deleted the shell element that was left from the solid mesh but I cant another 2d element.
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Use Element by config under(CTRIA3) extended entity selection menu.
    Altair Employee
    OP
    I deleted the 2d elements using your instructions and everything worked.Thank you very much for your help.
