🎉Community Raffle - Win $25
Join and Win
need your help: extract Ids from elements
dear for all
i need to extract nodes from several comp like green elements in ordered way:
the idea is to extract nodes from begin 1 to end 1 and from begin 2 to end 2 separately
i used  [hm_getvalue comps id=$compid dataname=nodes.id] --> no ordred Ids
any propositions?
thx
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.b00907d11e62893bc5c1c5344f16298b.png
1 - 7 of 71
    QuyNguyenDaiUser: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    I don't if there's a function to do that quickly.
    If not, you can build a ordered list yourself with Tcl.
    tinhUser: "tinh"
    Updated by tinh
    I guess, if hm generates free edges, it will create them ordered
    so try:
    *createmark elems 1 'by comp id' $compid
    *findloops elems 1
    *createmark elems 1 'by comp name' ^loops
    set OrderedNodes [hm_getmarkvalue elems 1 nodes 0]
    puts $OrderedNodes
    tinhUser: "tinh"
    Updated by tinh
    From version 2017 please try this command:
    hm_formnodelistsfrommark
    Or command:
    hm_getedgeloops
    thank you for your reply,
    for the first post: it is equivalent to: hm_getvalue comps id=$compid dataname=nodes.id
    for the second we use version 13 or 14
    i'm trying with  *markintersection
    tinhUser: "tinh"
    Updated by tinh
    'for the first post: it is equivalent to: hm_getvalue comps id=$compid dataname=nodes.id'
    Are them output ordered?
    As I tested, they are.
    yes they are but not as we wish :
    in this capture below we show how we want extract ids in two different lines
    thx
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.1be4388c19d2b5c415db76eabc844fcb.pngin this
    tinhUser: "tinh"
    Updated by tinh
    you can extract them by
    set index1 [lsearch $nodelist 353389]
    set index2 [lsearch $nodelist 352605]
    set ligne1 [lrange $nodelist $index1 $index2]
    set index3 [lsearch $nodelist 364500]
    set index4 [lsearch $nodelist 364593]
    set ligne2 [lrange $nodelist $index3 $index4]
