Hi @dracu777
Can you share details about the version and updates you are using?
Maybe by fitting the FBD area will reveal the other options.
Can you check if reducing the subcase area helps?
Hi Prakash,
I tried to move and fit the FBD area but It doesn't display the last part of that window. The version is HyperWorks Desktop 13.0.112 - June 2015
I don't know how to reduce the subcase area.
I remember I had the same problem with Hyperworks 11.0 when I was following the training course in an Altair center but I don't remember how they made it work...I should have taken a note.
Please, advice if you find a solution.
Hello,
Can you please try deleting the settings file.
Thankyou
Hello Sanjay,
Thank you for the reply. I tried to delete the file settings but it still doesn't work. Would it be possible to move the FBD window panel? In some CAD, like the model tree, it is possible to move it with the mouse to another position. I was thinking maybe, in that case, I can access the bottom by resizing it once free to move.
Hello Sanjay,
I tried but it's the same. I also tried to go through the options pressing the keyboard tab but at the end of the panel visualised, the selector moves to the visualization option.
I am thinking to connect the laptop to another video to see if the problem is the screen size.
Hi @dracu777
