Export from Hypermesh to ANSYS
Hello Everyone,
The objective is to go for exporting a 2d mesh created in hypermesh into ANSYS Wokbench.
The mesh has been created. I have exported the mesh to Ansys (Using Export-ANSYS). I have obtained a .cdb file which is the input for ANSYS Solver.
However when I am loading it in ANSYS I am not able to get the mesh for all the components of the assembly. Mesh for single component can be seen and rest all is not coming , even in geometry.
Only geometry and mesh was made in HM as I wanted to make contacts and BC's in Ansys.
Need help for the same.
Gopal,
Setting up a model in ansys is different from other user profiles, you will need to add an element type from the utility tab etc please see the below tutorial and follow the steps there
HyperWorks Desktop Applications > HyperMesh > HyperMesh Solver Interfaces > ANSYS:
HM-4410: Setting Up a Model in ANSYS
Hello Prakash and Rahul,
I was in Radioss Bullk Format and then went to tools>convert>Radioss(bulk data) to Ansys. As the conversion got completed, it got converted in to Ansys Profile. Then I have exported the .cdb file.
Is it possible to export only geometry and mesh into the ANSYS and assign contacts, boundary conditions , loads in ANSYS and solve there itself.
Hi,
Also the version for ANSYS is 15.0 and for hyperoworks it is 12.0.
Hi Gopal,
Ansys 15.0 is not officially supported with HyperMesh 12.0. Ansys 14.5 is supported with 12.0.110.
HyperMesh 13.0 supports version ANSYS 15.0 and earlier.
Hi Prakash,
I am able to import the file in ANSYS Mechanical APDL 15.0 but not in ANSYS Workbench platfrom of Mechanical. In Mechanical APDL also initially it was giving a warning for element shape check and later I switched it off. After this I was able to see my complete model in APDL. I want it to be imported in workbench platform.
Hii
I am trying to Export solver deck from Hypermesh to Ansys Using .cdb File but while opening of mechancal model in Ansys it gives message as conversion failed the imported mesh contains no element plz help me guys
Thank You...!!!!!
Hi Gopal_Rathore
can you confirm, that you are in Ansys profile when have exported from HyperMesh?
also, what is the version of Ansys are you using to import the file and what is the version of HyperMesh are you using?
