coupling EDEM with ANSYS CFD error at coupiler stage
I am trying to couple EDEM with Ansys CFD but it seems the solution files are not available for me to couple initiate the coupling serve.
i receive this error message. please find attached
Answers
Hi Tony,
For the EDEM install directory this is currently set to
\New Folder, I would expect this should be updated, typically this would be C:\Program Files\Altair\2022.2\EDEM\
Also I'd recommend using the latest version of the coupling program which is here:
https://community.altair.com/community?id=kb_article&sysparm_article=KB0117663
It allows you to use the 2022 version of EDEM.
RegardsStephen
1 -
Stephen Cole_21117 said:
Hi Tony,
RegardsStephen
Thanks, Stephens,
The
\New Folder, if the installation directory. i did not install it on the c drive as I do not have administrative permission to it. i don't know if that is the reason why. but I try the new coupling program and see what happens.
Thanks again
0 -
Have you solve this?HOW
0 -
Hi,
This link no longer works and I am unable to find any information on how to set up the coupling and compiler.
Can anyone inform me on where to find the latest coupling files and how to set up the compiler. Also, what best versions to use of EDEM and Ansys?
Thanks!0 -
0
