How to define Inertia reference point.
Hi,
I'm trying to verify the mass data (mass, CM, Inertia) for the flexible bodies that I've imported to MV. According to the info bar (see picture) the inertia data is with respect to the body system and the CM is wrt to the global system.
As default, the body system marker is coincident with the global system. I'd like the body system to have origin at the CM of the part, so that I instead get the inertia data presented wrt to the CM of the part.
This can be changed, however, when I change the body system marker location, then the part is translated in space. Thus, what I've accomplished is instead a translation/rotation of the part. Not the change of the reference point for Inertia presentation.
Is there a way forward within MV, or should I instead work with GRDPNT parameter in Nastran (optistruct?)
Cheers,
David
Hello David - For a flex body, the Body Coordinate System is a reference frame that positions the body. The inertia properties are derived from the flex h3d file.
You may obtain the inertia data with respect to the CG or any other point and coordinate system using Tools > CG/Inertia Summary
In the new MotionView interface (within the new HyperWorks
), the entity editor for the flex body shows the information as you expect, w.r.t the CG coordinate system
Regards
Praful
Thank you Praful!
Regards,
David
In the new MotionView interface (within the new HyperWorks ), the entity editor for the flex body shows the information as you expect, w.r.t the CG coordinate system
Regards
Praful
Regards
Praful
