how can I reach crash and safety tutorial model files on hyperworks 2021?
Hi , I cant reach the model files for crash and safety tutorials below on hyperworks 2021. How can I reach these models? Thanks.
Crash and Safety Tutorials HM-4640: Dummy Positioner In this tutorial, you will learn the different Default functionalities available to position a dummy in its environment.
HM-4650: Seat Deformer with LS-DYNA Pre-Simulation In this tutorial, you will learn how to setup a LS-DYNA model to simulate the seat deformation under the dummy.
HM-4655: Create and Modify a Seatbelt In this tutorial you will create a seatbelt system and all related solver seatbelt entities.
CRASH-2200: Pedestrian Head Impact Simulation The goal of this tutorial is to see how head impact simulation following the pedestrian safety regulation EuroNCAP can be defined using the Pedestrian Impact tool starting from a full vehicle model.
CRASH-2300: Create a Seat Mechanism Using the Mechanism Browser The goal of this tutorial is to create a seat mechanism.
